2003 D2 - First Time Owner Issues
Old Oct 10, 2019 | 02:34 AM
JUKE179r's Avatar
Originally Posted by greisinb
I would also recommend checking scrap yards, that’s where I found my D1 wiper blades for a mere 10 bucks!
Remember to grab all 3 wiper arms!
Old Oct 10, 2019 | 03:09 PM
screedle's Avatar
Atlantic British sells D1 wiper retrofit kits (and o2 sensors, amongst lots of others), so if you want something brand new that’s the place to start, they even have a video on how to do the replacement (very easy, just need a screwdriver and a ratchet).
Thanks for the suggestion, I will definitely check out local scrap yards and see if I can save myself some $$$
Old Oct 10, 2019 | 03:23 PM
screedle's Avatar
The local scrap yard has a couple of Discovery options on hand but is entirely self-service, meaning I will need to arrive with the appropriate tool(s) to remove the front and rear wiper arms from these vehicles. Is anyone able to advise the specific tool(s) I will need to remove the wiper arms?
Thanks!
Old Oct 10, 2019 | 04:11 PM
greisinb's Avatar
A flathead screw driver and an 8mm socket a deepwell or a short extension will probably work the best but a normal one should be able to get in there. Watch the video from Atlantic British:
https://www.roverparts.com/resources...-discovery-ii/
Old Oct 15, 2019 | 02:55 PM
screedle's Avatar
Is there a way to easily differentiate between a D1 vs D2? The local scrap yard with a couple of Discovery options does not maintain records on which specific model / year they have on the lot so I'm looking for a way to quickly know which one I'm looking at when I visit. I suppose one option would just be to snap a photo of my current wiper arms and compare against what they have, if it's different it's probably a D1.
Old Oct 15, 2019 | 03:09 PM
Jason Feuerstein's Avatar
Disco 1 has taillights below the rear window. On a D2 they're level.
Old Oct 15, 2019 | 03:12 PM
screedle's Avatar
Thank you!
Old Oct 15, 2019 | 04:03 PM
whowa004's Avatar
door handles is the easy way I keep track. D1 are flush and D2 are all raised grab handles on the exterior.
Old Oct 15, 2019 | 04:05 PM
screedle's Avatar
Driver door sticks when I try to open it and I'm curious whether this is a common issue with an easy fix?
Old Oct 17, 2019 | 06:50 PM
328Driver's Avatar
If the sunroofs are randomly opening it is more than likely that the sunroof ECM has gone bad. Mine would open an inch or 2 without me catching it letting rain in. It's fairly easy to get to and swap out. It's located behind the roof liner. I picked one up at the scrapyard for less than $20 and it fixed the problem.
https://www.ebay.com/i/302907965670?...saAijQEALw_wcB
