2003 Disco Head Gasket repair help...
Old Apr 26, 2011 | 10:55 PM
badicedog's Avatar
Default 2003 Disco Head Gasket repair help...
Hi guys, quick intro... I've been a long time lurker/reader, great advice you guys give! I have a 2003 LR Disco with leaking coolant issues and overheating during the past 4 months. I replaced the water pump with factory part. This helped for a while, then replaced throttle body plate/gasket. Again this was a short lived remedy and the slow leaking coolant began again. Recently I replaced the radiator, thermostat, upper radiator hose with factory parts. I put it all back together, flushed out the cooling system and test drove it. It overheated within 20 mins and the coolant was gone! I have not been able to located the coolant leak. I am taking a stab in the dark here but I think it could be a head gasket. Need advice...I read the "must read" for head gasket repairs but I am a bit confused. On a 2003 LR Disco does one need to check the preload on each rocker arm?
Old Apr 27, 2011 | 05:53 AM
Bundu's Avatar
Banned
Only if you are replacing the valve train... if you reuse your old stuff then nothing should change hey?
Clare Henderson
Engine & Internal
26
Dec 14, 2020 05:48 AM
BradyBug
Jun 19, 2014 07:09 PM
luke21
Engine & Internal
19
Oct 4, 2012 07:09 AM
ifthecar
Mar 25, 2012 06:34 PM
Pistonbully
Nov 3, 2008 03:25 PM
