2003 Disco II, fluid on garage floor
Old Jul 30, 2009 | 10:03 PM
presto777's Avatar
7th Gear
Default 2003 Disco II, fluid on garage floor
As a longtime Disco II owner of three different model years, I have noticed for the first time a small pancake sized fluid spot in the garage. 2003 Disco has 64,000 miles and just had 60k service. Looks like fluid is coming from main transmission housing. any ideas? Thanks, Preston
Old Jul 30, 2009 | 10:13 PM
sloppyjoe's Avatar
what color is it?
if its tranny fluid check the fill plug and pan bolts to see if something got cross threaded not torqued correctly.
also check the tranny cooler lines
Old Jul 30, 2009 | 10:16 PM
98roverguy's Avatar
Your gonna need to crawl under there and be a bit more specific. First of all is it trans fluid? What color is it? Does it taste like grandmas pancake syrup? If so you better invite me over for some flapjacks.
Pancake size aint good. See if your cooler lines are leaking. Thats an awlful lot for just a gasket or seal.
Old Jul 30, 2009 | 10:19 PM
presto777's Avatar
7th Gear
Roger that. thank you! Im taking it to LR Louisville (my home dealer) monday. Just wanted to be armed w/ some outside opinion before I went. The 60k service was done less than a month ago, and truck got a great report! I know that they are weepy/seepy machines, but this seems like a LR service writer could try to take me to tha cleaners for a simple repair.
Old Jul 30, 2009 | 10:22 PM
lipadj46's Avatar
Figure out what the fluid is and then try adding some white shepard's. Worth a shot.
Old Jul 30, 2009 | 10:37 PM
presto777's Avatar
7th Gear
All the following was seen UNDERNEATH truck: Fluid is brown. one small drop at seal where transmission meets engine. Tips of 2 bolts have brown drops on transfer case. Size of stain was size of beer coaster
Old Jul 30, 2009 | 10:39 PM
presto777's Avatar
7th Gear
Also, trans cooler lines are clean and heathy.....
Old Jul 30, 2009 | 10:41 PM
sloppyjoe's Avatar
possibly oil from the rear of the engine running down the tranny housing.
keep close tabs on your oil level.
Old Jul 30, 2009 | 10:51 PM
presto777's Avatar
7th Gear
SloppyJoe is correct. I now see very slight oil run on driver side rear corner of gasket cover. I have read that this is fairly common. I pulled up my 60k service report that was done last month and tech noticed this too. Must not have been too concerned b/c service writer wouldve had me address it then... Last question: How big of a fix does this gasket leak sound like?
Old Jul 30, 2009 | 11:01 PM
sloppyjoe's Avatar
easy.
go to sears and get a deep 8mm torx socket. tighten valve cover bolts. done!
