2003 disco II has p1300 p0303 p0305 p0307 p0135 p0300 p0307 p0130 p0303
Old May 7, 2013 | 04:00 PM
  #31
rtindle1975's Avatar
I just got the o2 sensor in today and I have to replace it anyway, so I will let you know. I think it has to be the o2 sensor, as the misfires are all on the same head on the same side as the o2 sensor, make sense? Or am I just being hopeful?
Old May 7, 2013 | 04:23 PM
  #32
pinkytoe69's Avatar
I don't know about rovers, but a bad pre-cat o2 can cause misfires in other makes.
Old May 8, 2013 | 11:35 AM
  #33
Originally Posted by rtindle1975
Ok, so I am driving home from work friday to change the cks sensor and low and behold, the three amigos visit. they have been coming and going since. I am going to do the type b fix soon.
Sorry I went off on tangent. After two hours, I finally unplugged the sensor. I also cleaned the MAF, flushed the engine and changed the oil with rotella. Drove around for about 30 minutes before it started coding again. I am not sure where to go from here, I have the new coilpacks, so i might just put them in for a hell mary and hope for the best.
When are you going to stop wasting your time playing with the COS, coils, MAF and everything else and realize, if you think about it, none of them can cut out an entire bank.
I told you that over the last few years a few other people had the same issue, wasted the same amount of time and money, didn't find the problem and sent it to a really well qualified mechanic.
Same holds true with your 3 amigos, why do a possible repair when in fact there are 16 reason why they will come on and with out scanning and finding the exact codes, you are again, wasting your time and possible money.
Old May 8, 2013 | 11:37 AM
  #34
Again, you are guessing, 02's will not cause misfires and should not be replaced, especially when you have no 02 codes.
Old May 9, 2013 | 07:57 AM
  #35
sloan74's Avatar
X2
OP, have your tried a simple seafoam treatment?
Old May 9, 2013 | 12:50 PM
  #36
Mike, thanks for your assistance, but I would rather you not comment anymore. You have a terrible attitude and frankly after reading your several replies you have made on other posts it is clear to me that you think you are superior to everyone on this forum and don't tend to treat anyone with any respect.
As for guessing, I am guessing on a lot of this, because no one seems to know and I just bought this vehicle and have no idea of its history. But I'm not guessing on the O2 sensor, I'm throwing a sensor 1 bank 1 code, which happens to be on the same side all my misfires are on. And as for O2 sensors not causing misfires, it's my understanding experience that O2 sensors can and do cause misfires.
So, mike, in closing have a great life, but please refrain from offering me your "words of wisdom". I bought this truck because I like tinkering and 4x4ing. I joined this forum to be around other like minded individuals. I clearly don't want your advice.
To everyone else, as always, thank you so much for your advice and help and I look forward to keep contributing to this forum.
Cheers!
Rocky
Old May 10, 2013 | 07:37 AM
  #37
Sloan, as stated, I am throwing a P0135, which is an O2 sensor code.
Old May 21, 2013 | 08:42 PM
  #38
gpelite's Avatar
Well looky here, I just bought a Disco II today with the exact same issues pretty much 3,5,7. I did because the mileage is sweet and the thing is a clean Cali Truck and this issue got me a deal and a half with a frustrated owner. I ran through some basic headgasket and coolant tests, zero indication of leaks. I got the wires, spark plugs done recently by previous owner, but I will check gaps thanks to this forum. After 2 days reading the forum Im going in this order.
-Pull Codes
-Seafoam her, because I want to and its the cheapest
-Pre-cat O2s swap out
-Coil
How did you come along on this since it has been a few days, still looking for the holy grail on fixing it before I dive in. Not gonna hijack the thread, gonna post my own, but I wanted to touch base
Old May 22, 2013 | 04:25 PM
  #39
gpelite,
I replaced the precat O2 sensors and did a seafoam fuel treatment and low and behold, the problem is solved. My advice, do the seafoam and if you have O2 codes, get an ultraguage, I could clearly see my O2 sensor wasnt working. And the seafoam worked as advertised and I could tell it ran much better. One other thing to note, only use supreme gas, it runs better.
Old May 22, 2013 | 04:26 PM
  #40
Also, thank you all so much for the help!
