2003 Disco II problems : ( HELP!
I have a 03 Disco II SE7 with 131k Miles. I was driving today and the rover randomly started studdering as I accelerated from a green light. I idled into the nearest parking lot and shut it off for about 30 mins. The car starts up but when i give it gas it chokes and dies. It's not over heating. The spark plugs/wires are fine. Maybe the Fuel filter or the fuel pump? Any suggestions would be great. thanks!
There is no fuel filter, and it's unlikely to be the fuel pump.
Why do you think that the plugs and wires are fine? Did you pull the plugs and see if they are?
Is the SES light on?
If it isn't, you are a likely candidate to be about the 75th person this month to need a crank position sensor. This is the time of year when marginal ones start to die from heat.
Lose spark plug wire it sounds like. I am guessing you only checked the wire sides connected to the spark plugs. Reach your hand back behind the upper manifold and make sure all the wires are connected into the coil pack. Do it when the truck it cold. That manifold gets super hot and unless you have hobbit sized hands, it's tricky to get them back there.
