2003 Disco II Vibration
Old Jun 22, 2009 | 12:29 PM
reddevildemo's Avatar
I think I found them but please let me know if they are correct.
U Joints- Neapco 1-0005
Ball Kit- Precision 617
Old Jun 22, 2009 | 12:50 PM
Try and get all the parts from the same manufacture so you will be assured of a perfect fit.
Are you planning on doing this rebuild, it is not suggested for someone who hasn't done it before.
Old Jun 22, 2009 | 12:56 PM
Well I was going to try it, I found a write up on how to do it. I have also replaced many u joints both in the garage and on the trail. Never a Cardin joint though.
Old Jun 22, 2009 | 02:12 PM
ozzer's Avatar
Mike or anyone else, is there an illustrative picture that would show what this u joint and centering bolt would look like if it has been done on an 03 DII? I want to inspect then order the parts from roverland or AB. Also, while we're on the subject, what is the part no. for the set I'll need for my 03 Disco.
Help has been invaluable on this forum. Thanks
Old Jun 22, 2009 | 02:49 PM
I found this for help but I am not sure what the year it is on.
http://static.scribd.com/docs/tkatf9...IAL_VIEW=width
Old Jun 22, 2009 | 03:01 PM
You are going to be looking for this type of grease fitting.
[IMG][/IMG]
And the part numbers will be the same for all DII's no matter the year.
Old Jun 22, 2009 | 06:08 PM
CampCobb's Avatar
Originally Posted by Spike555
No you cannot drive the truck with the front driveshaft removed...it just wont move.
Since you just bought it take it back to the dealer, in most states you have 7 buisness days/300 miles to have any issues resolved or get your money back.
Have their mechanic check the hubs, wheel balance, warped rotors, etc.
unless he bought it "AS IS NO WARRANTY" if he did then they are not liable.
Old Jun 22, 2009 | 06:12 PM
Which I did ofcoarse.
Old Jun 22, 2009 | 06:50 PM
Even when buying it "as is" there is still sometype of warrenty depending on where you live.*
Here there is such a law, if you drive it off the lot and the engine blows up you have a case, if you drive it across the country and then the egnine blows up then you dont.
*check local listings, your results may vary.
Old Jun 24, 2009 | 08:54 AM
I have the results from the tire shop. Both rear wheels were off by 1.5 ounces, left front was off by 1oz and the right front was off by 1/2 oz. This fixed the vibration I had.
Tom Woods front shaft going on order today and expected here next week. I will get that in as soon as I get it.
Thanks for all the help on this.
