2003 disco leaking fluid from under driver's side
Old Aug 29, 2014 | 05:01 PM
croller63's Avatar
Default 2003 disco leaking fluid from under driver's side
Looked under car today to see where leak was coming from and the steering parts are wet. Leaking steering fluid?
Old Aug 29, 2014 | 05:09 PM
croller63's Avatar
Pictures from under the driver's side.
Attached Thumbnails 2003 disco leaking fluid from under driver's side-image.jpg
Old Aug 29, 2014 | 06:03 PM
dusty1's Avatar
put some uv additive in and find the source.
my guess= return line or the pump
Old Aug 30, 2014 | 10:38 AM
croller63's Avatar
After I take out the p/s fluid with a turkey baster, then do I add the uv additive in or keep the p/s fluid in and add the uv stuff.?
Old Aug 30, 2014 | 10:55 AM
dusty1's Avatar
Just top it off with the additive.
Only takes a tiny bit and the pump will circulate and mix it
Samuel Baney
Apr 24, 2015 10:21 PM
aftermath431
Nov 19, 2013 09:59 AM
