2003 Discovery 2 front bumper removal
Lots of screws. Lots and lots of screws. 2 10mm bolts on each side and 2 more in the front. All 4 are under the painted finishers. But just when you think you got all screws there is more.
When removing the finishers start at the side closest to the middle of the bumper then move toward the tire for the part that wraps around the bumper.
On the 2003, it was not necessary to remove the grill or headlights. Bumper came off really pretty easily. Right now, my question is about the verticle holes that need to be drilled. Instructions say 10mm at one point and 6mm at another. The existing holes in the bracket are closer to 6mm but the hardware is much larger. What size bit is appropriate? Thanks.
Brumski07
05-01-2009 08:17 PM
