2003 discovery II SE
my wife was driving the rover one night and she seen someone pulled over by the road she said she pulled over to ask them if they needed help and all of the sudden her rover died.she could not start it, so she let it sit for awhile and then tried to start it and it started.she got out and talking to the people and the rover died. then she got back in it and started it back up again drove it home and parked it . the next day it started back up again but as i was pulling it out of the garage it died. i couldnt get it started. so i managed to get some help from a friend to push it back in the garage.later on that night my wife came home and said the rover started again . i dont know what the problem could be does anyone know. please help.
Sounds like your crank sensor is bad. This is very common on DII's.
www.atlanticbritish.com for a new one if you want to install it yourself.
spike555 i took the fuel pump out thought it was the problem and tested it with a 12 volt battery and it ran,dont know what the pressure should be, but i ordered a new fuel pump anyway just in case its not pumping out enough pressure. and i also have another question were is the fuel filter located ? is it inside the fuel pump or is it that screen on the bottom of the fuel pump?
