2003 Land Rover Discovery SE
Old Jun 28, 2020 | 12:22 PM
EdA117's Avatar
Default 2003 Land Rover Discovery SE
Hi All: My car overheats after 10 minutes of driving. Have a new radiator, new thermostat and all hoses are good. Told by local European car dealership probably have a blown head gasket. I did notice a lot of smoke coming out of my tailpipe a year ago, but been running well since. Thinking of fixing the vehicle. Costly repair obviously. Anyone have experience with this ? And what did you do? Thanks for help! Ed
Old Jun 28, 2020 | 06:55 PM
Robert Booth's Avatar
heh Ed! You’ll find more d2 guidance in the d2 section but head gaskets on a d2 is a couple of weekends work spread over 3 weeks depending on your machine shop turnaround. It’s one weekend to disassemble, a week at the machine shop, then a weekend to reassemble with new coil packs and plugs.
Old Jun 28, 2020 | 07:02 PM
Before you dive into heads though, is the car losing coolant ?
Have you tested for exhaust gas in the coolant ?
Does the cooling system retain pressure?
overheating could be because the system needs bled and the d2 is infamous for being more involved to bleed than earlier incarnations of the Rover v8
Old Jun 28, 2020 | 07:19 PM
EdA117's Avatar
Thanks For the very useful information. I will definitely bleed the system before I proceed with head gasket...Best! Ed
Old Jun 28, 2020 | 07:35 PM
Dave03S's Avatar
Do you know the proper way to bleed one of these?
A simple test you can do, when the engine is stone cold in the morning, is to open the bleed screw... If coolant is right to the top of that hole you are properly bled. If not you can use a small funnel or whatever else to add fluid directly through the bleed hole until it flows out, then replace the screw. Drive and repeat the next morning. after a few days it should no longer need topping off. If it does, you are losing coolant somewhere.
Old Jun 28, 2020 | 10:46 PM
redwhitekat's Avatar
You have a lot to read on here. Not sure on your mechanical skills but all the info you need is here.
Old Jun 28, 2020 | 10:58 PM
Someone should write a sticky on overheating causes what to look for and fixes
03_Rover
Aug 29, 2019 07:34 PM
Harvey Swift
Jan 19, 2015 12:08 PM
2003LANDROVERDISCOVERYRED
Feb 28, 2011 10:21 AM
03 Discovery
Jun 25, 2009 02:45 PM
l3x702
Apr 13, 2009 06:24 AM
