2003 S - Low speed pulsating
Old Jul 22, 2011 | 10:25 AM
jus_flyin's Avatar
7th Gear
Default 2003 S - Low speed pulsating
Hi all,
First off - fantastic forum. I have been reading for the last six months or so (had some issues setting up an account...apparently i'm not that IT savvy...).
Hoping for some help: I have a 2003 Disco with 148,000 km on it (I'm based in Canada, eh). The truck gets regularly serviced and I don't have any idiot lights on.
The issue: when I'm driving around town, cruising at say 1500 rpm, there appears to be a slight pulsating - almost like something is binding and then letting go. There is no fluctuation in rpms when this happens so it doesn't appear to be fuel / spark related. I also get the same thing happening if i'm coasting downhill at higher speeds. I thought it may have been a bad rotoflex, but there are no cracks evident. I recently changed the t-fluid to see if that would help, but no difference. I have also just changed the air filter and spark plugs on the off chance, again but no difference.
Any help / thoughts would be great.
Cheers
Old Jul 22, 2011 | 10:37 AM
drowssap's Avatar
So about 92000 miles? has the drive shaft and ujoint been serviced
Old Jul 22, 2011 | 10:38 AM
jus_flyin's Avatar
7th Gear
Oh, and additional info:
- No problems starting up hot or cold
- No hesitation when accelerating
- Gear change is smooth
- Gas mileage doesn't appear better / worse than over the last three years or so
- I changed the discs and pads about a month ago and didn't notice any caliper binding (the pulsating was happening before I changed the discs and pads too)
Cheers
Old Jul 22, 2011 | 10:42 AM
jus_flyin's Avatar
7th Gear
The servicable u-joints and shafts have been regularly greased at each oil change, but I still have the sealed u-joints on the front shaft: I put a call into a driveline place locally yesterday for a quote on a re-build and installation of greasable u-joints.
Old Jul 22, 2011 | 03:53 PM
sloan74's Avatar
front drive shaft would be my guess. esp if you feel it binding under there.
Old Jul 23, 2011 | 08:32 AM
jeffh's Avatar
if you think that there is an issue with your front drive shaft you need to STOP DRIVING NOW! wait until you get a new shaft put in.. if it goes you run the risk of loosing the transmission as well. treat this with the utmost of importance.
Let us know after you replace to see if that helps you with your problem.
Old Jul 23, 2011 | 08:37 AM
You can have a bent wheel, failed tire(belt shift), bad flange on t/case, failing Rotoflex.
Old Jul 23, 2011 | 11:35 AM
jus_flyin's Avatar
7th Gear
Thanks for the advice guys. I'm going to pull the shaft today and will get it re-built this week. I will keep you posted.
The odd thing about this pulsating is that it isn't consistent with speed - it's not like you feel it at 30mph and it get's worse as you speed up. When the rpms are over 1750, there is no pulsating. It onlly happens at ~1500rpm and when free-wheeling down hill (in gear, but foot off the accelerator). There are no bumps, whines, clunks or other concerning noises...
Cheers
Old Jul 24, 2011 | 09:38 AM
kman35ca's Avatar
Fellow canuck here EH! haha. Just wondering how much did the shop quote u at rebuilding your driveshaft?
Old Jul 27, 2011 | 11:43 PM
jus_flyin's Avatar
7th Gear
Hey,
Sorry for the non-response - just got back from a fishing trip. The first quote was stupid money: would have been cheaper to buy new. There are two other shops in town so I will give them a call tomorrow and will let you know what I hear. Need to get the truck back on the road for a camping trip in about three weeks so the sooner I get this sorted, the better.
I've also ordered a new rotoflex - figure may as well get it over and done with. I'll only likely be replacing it within the year anyway...
Cheers
