2004 D2 no start
2004 D2 no start
Went to start the truck this morning after sitting in my garage for 4 months with the battery disconnected and it cranks but no start. My check engine light is on with the two chime warning but my ODB scanner shows no codes which is odd. I have used the Bluetooth dongle on my LR4 to pull codes before and it worked. I’ll be working on this later today but thought I would post this to talk through troubleshooting. I hear the fuel pump turn on when I turn the key.
Thanks Richard, odd I am not seeing codes but I do have 3 lights on the dash when cranking....check engine, battery and oil. Maybe that’s normal when cranking? Fuses look fine and everything in the truck seems to be functioning as expected. I’ll try neutral and give it a try. Also pressed the inertia switch just in case.
Tried neutral but no luck. The dash indicator shows the correct gear but now the M and S lights are flashing. That could be from the battery getting low from all the cranking. It’s a new battery which I did charge just before trying to start today. That same battery got the truck in the garage under its own power 4 months ago.
