2004 Disco II - Who can do a head gasket in N Colorado?
My local LR dealer tells me that I need a head gasket replacement on my 2004 Disco with 112k miles. I can see small oil leaks at the rear and a small coolant leak at the front of the head.
The deal is quoting $3500 for the job which is too much for my current financial situation. Can any recommend some one better (cheaper) in N Colorado?
Thanks, Dougal.
Thanks, Dougal.
If you really want to do a thourough job including surfacing the heads it'll cost you more than $220. (Currently in the middle of doing the head gaskets on my 2002..)
I think I'm in it about $600 so far, but I'm also doing the plug wires, water pump, belts & hoses, some seals, & dropping the oil pan to clean the sludge out of it. The G** d**n previous owner used PENNZOIL. SOB.
