2004 Disco SE... need a (used/refurb engine)
Old 06-01-2010, 08:36 AM
core96's Avatar
Default 2004 Disco SE... need a (used/refurb engine)
Can anyone help me out with a reliable place to find a used or refurbbed engine for my 04 disco, also I've heard that the 4.0L could be used (from older models) any truth to that ? Would greatly appreciate any help and insight, thanks.
Old 06-01-2010, 09:16 AM
03discoman's Avatar
car-parts.com
Old 06-01-2010, 09:23 AM
kenk's Avatar
I would think a 4.0 would work, being people swap the 4.6 into the 99-02 that came 4.0
Old 06-01-2010, 09:26 AM
03discoman's Avatar
get 4.0 engine cheap ....
put your rods,crank,pistons and cam in it.....then you have a 4.6 again!!!!
Old 06-01-2010, 09:57 AM
Huge mistake, you will loose power and more importantly value if you throw a 4.0 in instead of a 4.6.
What is wrong with your, how many miles on your truck, where are you located and will you be doing the install?????
Old 06-01-2010, 10:15 AM
ljdiscovery's Avatar
If I am not mistaken, dropping a 4.0 into the truck may also create issues with you ecu. Also, isn't there a length issue of some sort? The 03, 04 use different front drive shafts from the 99 to 02 models, although that may be due to something aft of the bellhousing. Phil
Old 06-01-2010, 10:25 AM
He would need the ECU from a 4.0.
He would loose, are you ready? 8 horse power, the DII 4.0 has a wopping 192 hp, the 4.0 in the DI has 188 the 4.6 has 200 then 3.9 is 182hp.
The transmission is longer for the '03-04 models. It has a bigger pump.
As long as he uses a Bosch engine he can use any Rover engine he wants.
If he gets a 4.6 from a P-38 he can use his ECU, if he gets a 4.0 then he will need that ECU.
A DI engine will not work in any way, the Bosch has twice as many sensors as the GEMS.
Even though they use the same block and heads they have different things attached to them.
Old 06-01-2010, 11:42 PM
geotrash's Avatar
The 4.6 has 217hp.
Old 06-02-2010, 12:05 AM
d.m.disco's Avatar
Default 4.6 engine
Try Will Tillery at Roverguy.com. Great guy and engines are cheap. And most come with a 6month warrenty. Good Luck, Chris
Old 06-02-2010, 12:30 PM
Originally Posted by geotrash
The 4.6 has 217hp.
Thank you for the correction.
Quick Reply: 2004 Disco SE... need a (used/refurb engine)
