2004 Disco SE... need a (used/refurb engine)
Old Jun 2, 2010 | 01:24 PM
okdiscoguy's Avatar
All of the blocks are the same. again and again. The main difference is the front cover and timing set between a Gems and Bosch. You can program an ECU on a D2 to run a 4.6, so you can reverse on an 03-04. The heads are all the same with the exception of secondary air. You have to run secondary air on 03-04. That is the only problem with putting a P-38 4.6 in a disco (and plugging an oil port on the front cover).
What happened to your engine? overheat or oil starvation? If just your block is toast, you CAN take a bare 4.0 block, swap you internals and heads, and be back on the road. When I say internals, I mean everything that will come off. I have not checked crank clearance on the botom of the liners personally, so this is not personal knowledge. Hopefully soon it will be...
Old Jun 3, 2010 | 07:41 AM
oysterhead's Avatar
let us know what you find out in terms of price, warranty, etc.
Old Jun 3, 2010 | 08:03 AM
Originally Posted by ljdiscovery
If I am not mistaken, dropping a 4.0 into the truck may also create issues with you ecu. Also, isn't there a length issue of some sort? The 03, 04 use different front drive shafts from the 99 to 02 models, although that may be due to something aft of the bellhousing. Phil
Actually, I have been told by 2 shops, that you can, with the right scanner, go into the ECU and set it to a 4.o setting.
wyrdvans
Mar 2, 2016 06:19 AM
Shiftonthefly1
Mar 25, 2015 09:30 PM
DiscOklahoma
Mar 20, 2013 08:27 PM
rbaker
Apr 19, 2012 07:04 AM
fernando67
Mar 17, 2011 11:06 PM
