2004 discovery 2 engine misfire?
Old 09-29-2018, 11:21 AM
Best4x4's Avatar
Received 2,297 Likes on 1,688 Posts
No Problem, also while you are servicing your transmission you might as well replace the transmission filter. Auto Zone normally has the kit in stock. Only thing I've noticed with the kit from Auto Zone was the larger O-Ring wasn't as wide as the OEM O-Ring so I personally inspected my OEM O-Ring and re-used it. Besides that the filter, and gasket worked great. I've used several kits from Auto Zone with no issues.
Old 09-30-2018, 05:34 PM
Ok first thing at least on my list thanks to good old disco mike to do
you need a ultra guage to monitor your temps and give you a alarm if it goes over a certain temperature and you will read your own codes
2- replace your wires to 8 mm for better protection and rock auto has awesome prices on bosh coil packs
3 replace Tstat to 180 and change coolant to green stuff
those are the most important
than look on the sticky for disco mikes recommended maintenance
Old 09-30-2018, 07:37 PM
juicyhotsauce's Avatar
OK, cool thanks for all the information guys.
do you have a link for the ultra Guage and the wires that you recommended and the same with the green stuff and is there a video on how to install these?
Sorry I am so green I am willing to learn though and so far I have installed a two-inch lift an ARB bumper and a new power steering pump as well as fix all of the leaks in the sunroof. So I am at least capable. I think LOL
Shlocko
12-09-2021 04:19 AM
gulfstream69xr7
02-06-2017 11:28 PM
georgep
09-25-2015 09:39 PM
Fireman
11-23-2010 01:53 PM
Copguy
12-23-2007 06:16 PM
Quick Reply: 2004 discovery 2 engine misfire?
