2004 Discovery overheating
Old Dec 6, 2019 | 09:40 PM
Disco Aaron's Avatar
Default 2004 Discovery overheating
In need of help. My new to me 2004 disco with 82,000 miles is having some problems. Started with coolant being low when I bought it, so I added some. When I added some it started to spew out of the expansion tank. This went on for a couple of days. After those couple of days it’s started to overheat many times while driving down the road. Thinking it was a stuck thermostat I replaced it today with a 180° t-stat and a new line going from the engine to the t-stat. I also flushed the coolant system and added in 2 gallons of new peak 50/50 coolant and bled the system by unscrewing the bleeding screw on top of the radiator area. I went on a 50 mile drive and it ran perfect. However I went out tonight to dinner and all the sudden it started overheating again sitting at a red light. I pulled over immediately and found steam pouring out the spew hose on the expansion tank and coolant to be very low. I unscrewed the bleeder screw and steam constantly poured out. I added in more coolant and still overheated. Not sure where to go now. Need help!!
Old Dec 6, 2019 | 09:59 PM
Also wanted to mention I did an oil change at the same time as well. The oil had no coolant in it.
Old Dec 6, 2019 | 10:05 PM
Frank4's Avatar
you’ve still got air in the system. Unscrewing the screw on the T junction will not completely bleed the system. You have to raise the expansion tank and use the screw on the T junction.
Old Dec 6, 2019 | 10:20 PM
Thanks for the quick reply. I’ll give that a shot once I limp the truck back home. Does that explain for the loss of coolant though?
Old Dec 6, 2019 | 10:23 PM
Dave03S's Avatar
What he said but do that with the engine cold. Stone cold.
Old Dec 6, 2019 | 10:27 PM
CollieRover's Avatar
Run to autozone and rent a coolant pressure tester. You can pump it up and make sure it has no leaks, and holds pressure.
Old Dec 6, 2019 | 10:39 PM
Will do and will report back with results. Thanks for quick reply...
Old Dec 6, 2019 | 11:19 PM
Frank4's Avatar
You might not be losing any, it could have never been filled properly.
Old Dec 6, 2019 | 11:40 PM
True, good point. Hopefully that’s the issue.
Old Dec 6, 2019 | 11:41 PM
was gonna go at it tonight but I guess I’ll hold off till the morning when it’s super stone cold.
