2004 Discovery Winch
Is it possible to attach a winch to a factory nudge bar on a 2004 Disco? (Sorry if this is a dumb question). I will eventually get around to replacing both front and rear bumpers while adding a 2" lift, but for now I'm curious if I can mount using stock equipment.
*If so, any winch recomendations? Thanks!
12000 lb. Off-Road Vehicle Electric Winch with Automatic Load-Holding Brake
You could do a frame mounting/ discreet mount
Exactly what I was going to say.
Lucky8 Llc. - Take the road less traveled...
do you guys have those spring mounting license plate brackets?
they make the set up so much simpler......keeps you from leaving your plate on the ground while you're getting out of ditch
then getting in a hurry and leaving it there, then spending a couple of hours going back and looking for it, then not finding it, then getting a ticket for not having it. I did all of those things.
