2004 fan clutch
Old Jul 17, 2012 | 03:45 PM
andrew12159's Avatar
Default 2004 fan clutch
So after reading the posts about severe duty fan clutches in the disco 2 forums I bought one. It does not work. My fan and clutch are one. What year did they change? What are the people with one piece fans/clutches doing?
Old Jul 17, 2012 | 04:05 PM
Bkreutz's Avatar
03 and 04 are different than early ones. (but I think the hub on the water pump is the same so you could possibly put an earlier clutch/fan combination on it)
Old Jul 17, 2012 | 05:01 PM
jafir's Avatar
I think the 03 04 fan is better, more blades, and it's a little cheaper than the 99-02 assembly, of course it's more expensive in this case since you don't need the whole thing.
You can get just the 99-02 blades, but by the time you add the clutch, you are pretty close to the price of a new assembly.
http://bputah.com/Disco2%20Parts/Lan...e_ERR4960.html
http://bputah.com/Disco2%20Parts/Lan...h_ERR4996.html
Old Jul 17, 2012 | 07:25 PM
antichrist's Avatar
The Hayden 2991 server duty clutch for the DII is less than $60.
Old Jul 17, 2012 | 07:54 PM
What do you do for blades?
Old Jul 18, 2012 | 06:08 AM
drowssap's Avatar
you can use a fan blade for a 99-02, pick one up at a boneyard for a few bucks
Old Jul 18, 2012 | 12:10 PM
Paul Grant's Avatar
I've got just the fan blades for $30 if anyone needs them.
Old Jul 18, 2012 | 01:56 PM
The older fan will work fine on your 4.6.
Old Jul 18, 2012 | 10:34 PM
I got it sorted. I used'02 astro blades for $37 at autozone in stock. Perfect fit for the '02 astro severe duty fan clutch. Had to trim blades a little.
Old Jul 19, 2012 | 06:53 AM
That could be a mistake. First you never trim the blades, that weakens them and they will crack and second, you should not use a HD clutch, draws too much horse power.
