2004 homelink help
Old 06-26-2010 | 12:11 AM
00&04 Disco's Avatar
Default 2004 homelink help
I was looking to put homelink in my 2004 disco. I found one for 30 bucks and was wondering since my disco is the "cheap" S model and homelink was not standard, should it still have the wiring? I pulled the plate off of where the homelink should be and there were two different strands of wires; one running to the auto dimming mirror and the other strand running to the light. I know most discos have the wiring for different options but not the buttons like the heated seats and fog lights in front. Is there a way to hook this up since I am unable to find the connector that should connect to the homelink system?
Old 06-26-2010 | 07:53 AM
You may find if you have one of the newer garage door openers that even if you hook one to your car it won't work cause the old D2 Home links were more for fixed frequency doors, not the new doors that always change frequency.
Old 06-26-2010 | 08:39 AM
starrock's Avatar
i actually just programmed the stock homelink in my '02 last weekend to my 2 garage doors on my 3 year old home. the owner's manual gives clear instructions on how to do this on garage door openers with "rolling codes." so, it is possible. working great!
ive attached links to my picasa dropbox with photos of the pages in the manual discussing this
brian
http://picasaweb.google.com/lh/photo...eat=directlink
Old 06-26-2010 | 12:14 PM
03discoman's Avatar
you will have the harness there in your truck...its just plug and play....
Old 06-26-2010 | 08:26 PM
Discoman,
Where would you find the harness? I would think it would be there but the two wire strands are running to the light and mirror and there is not an extra strand not used. Would it be possible that mine does not have the power wire run up there? Or do you think it is not pulled that far down and I might have to take the plastic cover (whole overhead peiece)off where all of the empty spots are and try to locate it?
Old 06-27-2010 | 07:33 PM
03discoman's Avatar
IIRC....there compass and homelink mirror in my 2003 only need 12v to operate...... so...there shouldn't be a second harness if you have the compass in the mirror..... just swap the mirrors out and give it 12v...
Old 06-29-2010 | 10:53 AM
JerrodSteph's Avatar
Thanks for this thread, I just programmed my 03 disco and our 06 dodge caravan today they each use the homelink system, same instructions, cool!
Old 11-01-2011 | 10:10 PM
dparham's Avatar
How do I know if I have Homelink on my New ( used 03 Disco SE ) ?? I see my mirror has 3 buttons on is and a directional finder... is that the homelink?
Old 11-01-2011 | 11:56 PM
souljad9's Avatar
03-04 had homelink in the mirror. Previous years used the module in the ceiling console.
Old 11-02-2011 | 02:06 AM
DaveBFoto's Avatar
I open the gate in my apartment complex every night with my homelink. Love it As long as the gate/door is fixed frequency it's incredibly simple to set up.
Quick Reply: 2004 homelink help
