2004 HSE Oil leak help!
Old 08-19-2020, 11:37 AM
kgov's Avatar
Default 2004 HSE Oil leak help!
I have a large oil leak coming from the front bottom of my 2004 HSE Discovery 2 with 140k miles. I thought it must be the front seal behind the crank/harmonizer pulley. Attached are pictures. I recently replaced that seal and just drove it around and am still having a massive leak. Everything was sprayed off and cleaned after the seal change as well.
Can anyone help diagnose?
This is during change of the seal
This is after the seal was changed and 10 min of driving around.
Old 08-19-2020, 11:41 AM
Richard Gallant's Avatar
Received 1,178 Likes on 815 Posts
seal if it is not installed right it will keep leaking
Old 08-19-2020, 11:45 AM
kgov's Avatar
Is there a write up on that install somewhere? Cuz I just took the old one out and put a new one in flush to the metal with a block of wood and a whole cut in the wood. Wasn’t sure if it needed to go in farther or not.
Old 08-19-2020, 01:27 PM
Red5's Avatar
I would pull the belt and pulley and idle the engine for a minute. Since it's leaking that fast, the issue should show itself quickly.
Old 08-19-2020, 09:23 PM
kgov's Avatar
I’m fairly certain it’s just the same seal that’s leaking again does anyone know how far it needs to be in and do I need to replace it now with a new one or can I use the same one?
Old 08-20-2020, 10:02 PM
Extinct's Avatar
Received 1,509 Likes on 1,069 Posts
Post a photo of your harmonic balancer shaft OD. You may have a big groove. Also, you need to do the PCV mod. Do a search. Is the back of the balancer soaked in oil, or only the pan? A leak on the id of the seal will soak the balance and sling oil everywhere. A leak on the OD of the seal will only run down the pan.
Old 08-21-2020, 09:49 PM
kgov's Avatar
Here is a picture of the pulley. I cleaned it up pretty well and there doesn’t seem to be a groove really if so very very microscopic.
Old 08-22-2020, 07:33 AM
Extinct's Avatar
Yeah, pulley is not the problem
Old 08-22-2020, 09:12 AM
zski128's Avatar
Here is a picture of a front cover I removed from an engine. The seal is slightly below the face by about. 1/16th or so. Not sure if that’s the problem.
Old 08-23-2020, 04:10 PM
rhyslegge's Avatar
Last time I replaced my front main seal i drove it home until it bottomed and wouldn't go any further, looked about the same as the photo above. No leaks after 5,000 miles so far.
Rhys
Quick Reply: 2004 HSE Oil leak help!
