2004 Land Rover discovery overheating no coolant leaks
I have a 2004 Land Rover discovery I have bled the coolant system multiple times however there is still an air pocket somewhere? It will overheat When I am at idle, I have to turn the heat on in order for it to stop overheating could it be a fuse for a fan that’s not turning on when it’s getting hot? I also replaced the radiator about two years ago could it be a clogged radiator? Please point me in the right directions to diagnose this problem I also have a little bit of sloshing coming from my dashboard. last week I also replaced the heater plate on my throttlebody that was leaking i’m sorry if I posted this to the wrong thread I am new to this forum thank you!
the dash gauge is pretty useless as it has three basic positions, Cold, Operating temperature, and WAY TOO HOT.
How long does it take to get hot? Does it overheat in all conditions? Most common issue is malfunctioning thermostat. With the inline thermostat mod you can remove the thermostat temporarily, allowing coolant to circulate freely. If it still overheats them, it is probably a clogged radiator. Characteristic of clogged radiator is substantially higher temperature on the inlet side vs outlet side of radiator. IR temp gun is a big help to troubleshooting.
DiscoID (02-14-2021)
Sunflower
11-10-2018 02:05 PM
indiefantv
11-05-2012 10:10 PM
