2004 Land Rover discovery overheating no coolant leaks
Old Feb 14, 2021 | 12:16 PM
Dpino456's Avatar
Default 2004 Land Rover discovery overheating no coolant leaks
I have a 2004 Land Rover discovery I have bled the coolant system multiple times however there is still an air pocket somewhere? It will overheat When I am at idle, I have to turn the heat on in order for it to stop overheating could it be a fuse for a fan that’s not turning on when it’s getting hot? I also replaced the radiator about two years ago could it be a clogged radiator? Please point me in the right directions to diagnose this problem I also have a little bit of sloshing coming from my dashboard. last week I also replaced the heater plate on my throttlebody that was leaking i’m sorry if I posted this to the wrong thread I am new to this forum thank you!
Old Feb 14, 2021 | 01:29 PM
cfz2882's Avatar
could feel the hoses as the truck warms up to see where the circulation is and isn't- especially the thermostat housing.The electric fan is not needed during normal operation,but may come on if coolant temp high.
Old Feb 14, 2021 | 02:07 PM
jastutte's Avatar
how are you reading the overheat condition? with the dash gauge or with an aftermarket OBD2 reader?
the dash gauge is pretty useless as it has three basic positions, Cold, Operating temperature, and WAY TOO HOT.
Old Feb 14, 2021 | 05:53 PM
Extinct's Avatar
How long does it take to get hot? Does it overheat in all conditions? Most common issue is malfunctioning thermostat. With the inline thermostat mod you can remove the thermostat temporarily, allowing coolant to circulate freely. If it still overheats them, it is probably a clogged radiator. Characteristic of clogged radiator is substantially higher temperature on the inlet side vs outlet side of radiator. IR temp gun is a big help to troubleshooting.
Sunflower
Nov 10, 2018 02:05 PM
Buttercup73
May 30, 2017 06:06 PM
kmarkou
Oct 14, 2015 06:25 PM
indiefantv
Nov 5, 2012 10:10 PM
