2004 neither shaft spinning
My 2004 disco started having the differential shifter slip out of high while driving, mainly decelerating. Then all of a sudden some terrible grinding and it wouldn’t drive. Runs fine, but put it in gear or reverse, terrible grinding sounds, and neither shaft will spin. This has to be a bad transfer case, right? Or could it be something else ?? Thanks y’all
And not easy to drain if you have an 03/04, haha. Still can't figure out how to get around that stupid crossbar so perfectly in the way.
Service should be checking and or changing the oil depending on mileage.
I bought one of those little water sprayers you pressurize to water plants with. Mine is 1/2 Gallon. Put the oil in the can pump it up and squeeze the trigger. I am going to do the same thing with the transmission oil service.
But back to the OP, it certainly sounds like the t-case is the problem.
Step back a minute. Are you sure it’s either in high or low range and fully engaged? A simple check, can you feel the shifter actually engaging between high-neutral-low or look underneath to make sure the linkage is connected and moving.
