2018 Wish List
Addition to old list in 2017 topic...
Another 2" of lift.
These...
https://www.ebay.com/itm/4-NEW-315-7....c100677.m4598
Or these...
https://simpletire.com/lexani-lt315-...t1675030-tires
Hub-centric wheel spacers.
Cut wheel wells.
Do the "Lincoln" locker in rear.
Rear bumper winch.
Brian.
Another 2" of lift.
These...
Or these...
Cut wheel wells.
Rear bumper winch.
Brian.
My 2018 wish (and fix) list for Myrtle is:
- swap and rewire upper reverse lights for lower turn signals and vice versa
- repair cracks in windshield
- replace NGK doughnut and hardware on rear propshaft
- replace 2x UJ in rear propshaft; get balanced at hi & low speeds
or
- get new Tom Woods rear prop shaft
- add Disco 1 tranny pan & dipstick
- fix stuck wipers at column switch
- replace leaking rear window washer pump
- remove stock aux light relay with relay mod and latching switch
- replace all 4 ball joints
- replace stock panhard, drag link & track rod assy with Terrafirma
- replace steering dampener with OME #OMESD02
- replace stock front shock mount towers with RME
- replace cracked rear door latch cover
- install metal covers to rear bumper
- add 3/8" x 8’ of hose to inside of driver’s window seals
- add 3/4" x 6’ of hose to inside of rear door seals
or
Head gasket repair.
In line t-stat, all alum radiator & catch can, all other cooling sys mods.
Oil press, coolant temp, fuel press gauges.
Fix my DS door motor.
Glue my rear view mirror back on.
Remove headliner, paint.
Remove and store rear seat, cargo drawer system.
Re-sew DS seat base.
Fix loose instrument cluster, replace odometer light bulb.
Fabricate better center console with room for gauges and decent cup holders!
Safari roof rack.
Fab custom front and rear bumpers. Winch. Lights.
Fix fading paint.
Fix and install front driveshaft removed years ago.
Oh, yeah, the option B 3 amigos thing.
That's it, not much to make me happy.
Am I missing anything? Notice I'm not even asking for a lift!
Safari roof rack.
Fix fading paint.
