235/85 vs 265/75?
235/85 vs 265/75?
OK, I've been on here long enough to notice most recommend against running 265/75 on a D1. I currently have 2" lift and 245/75, with no trimming or rubbing at all. I am contemplating getting a 3" lift (and the nessesary mods like caster correction,brake lines,etc) and running either a 235/75 or 265/75.
I know either will require fender trimming. But the only diff between these two sizes is a little over an inch diff in width, same diameter. Does that inch really make that big a difference(no pun intended)? Does anyone here run 265/75 on their d1?
Thats a ridiculous tire for 80% road driving. Looks more like a swamper tire than anything.
Why not buy a more aggressive A/T like goodyear duratrac's.
If you do face a lot of mud, then Id recommend some Discovery Cooper STT's. Couple of my friends have that tire, and on the highway its not bad for the tread and the effectiveness you get in the mud.
I did look at the duratracs, they're almost $200 a piece in that size. And if thats a ridiculous tire for street,so would the STT's(which are also almost $200/piece). I have the cooper s/t's which are a fairly aggresive a/t, just want a little more than that.
s4lex
08-11-2008 04:58 PM
s4lex
05-02-2007 10:10 PM
