235/85R16 tires on 8J wheels
You could certainly do it, but the tire isn't designed for it and it may not last as long. I'm running that size on a 7" rim so I can't say from experience how it will do. The tread will probably wear unevenly unless you find a sweet spot with tire pressure. If you run at lower psi than the tire "wants", heat can cause problems that will cause premature failure. Plus you may be more prone to lose a bead at very low pressure when off pavement. A better choice w/b 265-75 which is about the same height but wider and more appropriate for the 8" wheel. Many others run that size with the common 1.5-3" lift.
wjsj69 (08-05-2018)
