245/75/16's . . . anyone run these? would a 2" lift clear em?
Old May 15, 2006 | 10:35 PM
2k2wranglerx's Avatar
Default 245/75/16's . . . anyone run these? would a 2" lift clear em?
i'm in need of some new tires and i was wondering, would a 2" spacer lift clear 245/75/16's? 31" tires basically. The reason i'm wondering is that's the same size stock jeep rubicons run. They're pretty easily had and i figure if i'm replacing them anyway . . . . . Plus MTR's are pretty good in the rain/snow. . .
any input on this?
Old May 15, 2006 | 10:58 PM
Default RE: 245/75/16's . . . anyone run these? would a 2" lift clear em?
Are you talking about a D1 or DII?
Either will take a 245 with out a lift.
If you are buying new tires consider the BFG MT's, they will out last the MTR's on and off the road.
The MTR has a little sipping that will help on wet surfaces, that is the only plus.
Just food for thought.
Mike
Old May 16, 2006 | 02:26 PM
hoberock's Avatar
I have a Disco I with a 1.75" lift and 31" tires. Some rubbing when I am wheeling and the car is loaded.
Tim
Old May 16, 2006 | 09:26 PM
s i don't have to lift it at all to clear 245/75's? i have a 2002 discovery II . .is that better or worse?
I've run quite a few types of tires. on my old TJ (jeep) i ran
GSA's
BFG MT's
Sidewinder MT's
BFG AT's
Pro comp xterrains
TSL's
IROKS
MTR's
Boggers
Baja claws
pretty much covers it on the TJ.
The MTR's are cheap since people remove them from their rubicons when they go bigger. So there's lots of them out there.
Old May 16, 2006 | 09:41 PM
ORIGINAL: 2k2wranglerx
GSA's
BFG MT's
Sidewinder MT's
BFG AT's
Pro comp xterrains
TSL's
IROKS
MTR's
Boggers
Baja claws
The wheel wells on a DII are larger and more forgiving so 245's will work well for you. I understand what you are saying about the MTR take offs, the price is usually great.
Good luck,
Mike
Old May 17, 2006 | 04:45 AM
opus13's Avatar
i run 245/75r16's on a 3" lift with (no wheelwell trimming done) and still run into a little rubbing when in a tight turn. its nothing unmanagable, but it's definately occuring.
Old May 17, 2006 | 02:22 PM
ORIGINAL: opus13
Yes, I noticed the rub on my DII with 265's when making full teuns. They are rubbing on the front radius arms, which are large and flat with no sharp edges to cut the tire. I did co,promise a little and make a slight adjustment to the steering stops to minimize the rubbing with out hurting my turning radius too much.
I think it is a personal judgement call each has to make.
Mike
Old May 17, 2006 | 02:54 PM
CronicJoeBlunt's Avatar
I am running the remmington Wide Brute RV 245/75R16s on my 95 4.0 SE with no problem. I have the coil spring conversion instead of the air bags but that is it and they do not rub at all.
Old Jun 18, 2006 | 05:38 AM
NEWtoDISCO's Avatar
8th Gear
i've got 245/65s that barely rub when really getting the rover twisted up, and it's a stocker...
Old Jun 19, 2006 | 05:18 AM
disco12's Avatar
I got 265's like disco mike it rubs on the radius arms but that will fixed soon The D1 a D2 will work just find with 245's u made have to trim a little around the wheel wells if it is a D1.
m3dragon
Feb 24, 2015 10:08 AM
wisconsinoverlander
Apr 26, 2012 10:24 AM
