285/75/18 tire lift?
Old Jan 22, 2014 | 12:07 PM
BayerischeDisco's Avatar
Default 285/75/18 tire lift?
So I was given a set of 285/75 or 70/18 tires. Would the 2 inch lift be enough?
Old Jan 22, 2014 | 03:13 PM
kwarren76's Avatar
I'm running 275/65/18 with a 2" HD OME lift and I rub a little on a fully locked left turn.
Old Jan 22, 2014 | 03:36 PM
dusty1's Avatar
wheel spacers can fix the turn rub. I've got some laying around from when i was running that set up.
should be fine with articulation, i think i touched my wheel arch a couple of times, but no damage no problem.
Old Jan 22, 2014 | 03:41 PM
ZGPhoto's Avatar
FYI a 285/75 r18 is nearly a 35" tire and no it will not fit with a 2" lift.
Old Jan 22, 2014 | 03:54 PM
dusty1's Avatar
true dat ^...was thinking 265
Old Jan 22, 2014 | 09:17 PM
Ok so what would it take. 3+ or bigger?
Old Jan 22, 2014 | 09:19 PM
ZGPhoto's Avatar
Well do you go off road at all? It'll take at the very least a 3.5" lift, non-significant cutting, and if you do go off road it'll require diff and half shaft upgrades. If you just drive on the road, 3.5" lift, spacers, and upgraded gears.
Old Jan 22, 2014 | 09:23 PM
Charlie_V's Avatar
I have 285/65s and a three inch lift. I had to move the turn stops out to prevent rubbing. Got tired of that quick. Then I got 2 inch spacers and now they rub when I hit a bump and am turning.
I think you need more than 3 inches, or 3 inches and a body lift. Or 3 inches and a fender cut. My avatar is without the spacers.
The spacers and lift look neat though.
Old Jan 23, 2014 | 01:44 AM
Dane!'s Avatar
Its a lot of money for gears and axles just to fit some tires. I'd say sell them, and maybe get a smaller size that wont cost a lot of $$$. Like a 32 or 31'' tire on a 2'' lift or a 30'' on stock.
Old Jan 23, 2014 | 10:37 AM
SuperSport's Avatar
I'm not sure the Comperable size of 18", but I'm running 265/75/16 with NO lift and no rub.
31.5" x 10.75" Just measured.
Attached Thumbnails 285/75/18 tire lift?-tires-3.jpg
