2nd to last straw...
On my way to work, truck idling really low I pull over give it has it bogs down, you can't give it any gas or it'll bog down and die I'm thinking crankshaft position related...
I haven't had 1 good experience with this truck yet, I'm thinking engine was rebuilt or head gaskets, I'm finding wires that just seem out of place. Is so close to getting another diesel jetta or something
Put a code scanner on.
Look for pending codes.
Drive it with a code scanner looking live.
Look at fuel trim.
Look at O2 sensors.
Look at speed
Temp.
All these need to be accurate.
One of these may be fouled up.
You seem to have time to post on here but not time to look at your truck.
You must have computer access at work like most of us.
No harm, no foul.
Of course we are curious and want to help.
Look at fuel trim.
Look at O2 sensors.
Look at speed
Temp.
No harm, no foul.
Look at fuel trim.
Look at O2 sensors.
Look at speed
Temp.
No harm, no foul.
Look at fuel trim.
Look at O2 sensors.
Look at speed
Temp.
No harm, no foul.
I'll inspect when I get off at 5 In the morning.
Anyways just realized its the camshaft sensor, which to me is better.. And I think I may know where the short is. Ah, the joys of a LR. I swear one more thing and its *** is grass.
The cam sensor is twice as much as the crank sensor.
If it is bogging down when you give it gas it is most likely a fuel issue, check your fuel PSI before replacing anything.
Think about it, you press the throttle and the butterfly opens letting in more air, if there is not more fuel also going in it is going to run to lean and bog down.
Same thing if it were getting to much fuel and not enough air but that is almost always accompanied with black smoke.
My money is on the fuel pump.
