3" lift necessary changes
What would need to be adjusted or replaced on a '97 Discovery that has been lifted 3". Please be as specific as possible and don't be afraid to be **** about the details (like brake lines or bushings). I want to know what is going to be involved before I jump in.
RE: 3" lift necessary changes
clearance for bigger rubber is a major reason and I don't want to be trimming the fenders. Also, I figure if I am going to lift it I might as well make it worthwhile. I have read some discussion about driveshaft replacements etc but want to know everything involved. mainly I see the three inch lift as the first step to creating a moderately modified discovery: not too extreme but more capable than stock
3" Lift with OME Shocks (For RRC, D90, and D1 only)
# OME N73 front shocks,N25 rear shocks $349.00
# RTE springs $315.00
# Rear spring Retainers $45.00
# Brake lines $26.00 each (4 or 6 lines required)
# Rear Links w/bushings $325.00
# Front radius arms w/bushings $325.00
Kit #1 price $1385.00 (depending on number of brake lines)
3" Lift with Rancho Shocks (For RRC, D90, and D1 only)
# Rancho RSX9000 shocks $349.00
# Rear shock mounts $155.00
# Rear spring retainers $45.00
# Rear links $325.00 w/bushings
# Front radius arms $325.00 w/bushings
Kit #2 price $1540.00 (depending on number of brake lines)
3" Lift with Bilstein 7100 Series Shocks (For RRC, D90, D1 and DII)
# Bilstein 7100 series shocks $720.00
# Front shock towers $96.00 (not required on DII)
# Front lower shock mounts $35.00
# Rear shock mounts $155.00 (not required on DII)
RRC, D90 and D1 Lifts Include:
Kit Price for RRC, D90 and D1 - $2042.00 (depending on number of brake lines)
DII lifts include:
# ABS Extensions $75
# Crossmember Spacers $30
# Bilstein Reducer Bushings $40
Kit Price for DII - $1286.00 (depending on number of brake lines)
http://rovertym.com
DII lifts include:
http://rovertym.com
ORIGINAL: BayouDisco
You may need to change to longer front/rear drive shafts. Someone else can chime in. I have a DII so I'm not sure.
3" lifts for Discovery's is A lot of lift. Most people get by with 2" lifts because they are a lot cheaper and you do not need to change as many suspension parts for it to work.
How big of tires do you plan of running?
mrcrptguy,
really? I had heard from a few people with 3 inch suspension and no body lift that they needed to get new stuff... Does it look like anything else is getting too close for comfort? I want to go with a similar lift, but I'm worried about flexing out a wheel too far and breaking something or some crap like that.
