3.9 v8 spluttering
Old Oct 16, 2009 | 11:08 AM
v8 cope's Avatar
3rd Gear
Default 3.9 v8 spluttering
hello, i have an "R" reg discovery 3.9 v8 with an LPG conversion, the problem is the car seems to splutter and loose power when full throttle is applied.
ive changed dizzy cap and rotor arm (the arm was arking), its always had recent services etc.
ive been told to try some performance ht leads becuase the current ht's dont seem to be ignighting the lpg properly, could this solve the problem?
this is the set ive been looking at
http://www.formulapower.com/?gclid=C...FYwA4wodyQ7crQ
are these any good or does anyone have any recommendations with this engine?
any suggestions or help is much apprieciated
cheers!
Old Oct 16, 2009 | 02:51 PM
lipadj46's Avatar
Sure it could be your wires if they are old or ot made to take high temps. These are proven wires and a favorite around here:
http://www.apexperformance.net/CartGenie/prod-1155.htm
Old Oct 16, 2009 | 03:35 PM
v8 cope's Avatar
3rd Gear
it says they are not for the disco series..?? any alternatives (pref a uk company)???
thanks for the help.
Old Oct 16, 2009 | 04:06 PM
lipadj46's Avatar
That was for a DII, here are the wires for a DI: and most other land rover models are available at the same website.
http://www.apexperformance.net/CartGenie/prod-1156.htm
Ask Urban Panzer where he gets his wires, he's from the UK.
Old Oct 16, 2009 | 09:02 PM
Those wires look ok to me, try that and if that does not cure the problem look into replacing the coil.
If it cant send enough spark down the leads then it will cause rough running.
Old Oct 17, 2009 | 05:45 PM
v8 cope's Avatar
3rd Gear
thanks for the advice!
Old Oct 18, 2009 | 06:06 PM
Let us know how it works out for you.
