3 Amigo help
3 Amigo help
Ok guys, I need some help. I had the dreaded 3 Amigos for some time, so this weekend I thought I would try the bypass - option B. I took the modulator off and pulled the switch. When I pulled the switch it was covered in ps fluid. Once I had the switch out, one the eclips to a valve was laying in the switch. It had broken in half. I new this was my problem. I ran to Home Depot and was able to find a clip to fit (and bought a new hex screw since I stripped it while trying to remove the switch without take off the modulator). I did the bypass and bled the brake. Started the truck and our three friends were gone. I might have driven it 30 miles since the bypass.
Today, I move the truck. The brakes seemed a bit squishy, so I decided to bleed the brakes again. Now they seemed stiff. But to ensure I got all the air out, I activated the hill descend first while in high and it would not blink and chime. The yellow light with the exclamation point showed up instead. Then I decided to put the truck in low gear and see if I could get the hill descend to engage. This time the red brake light appeared. I drove the truck home and as I pulled in the driveway, the 3 amigos reappeared. I then disconnected the bypass, started the truck and turned it off. I then reconnected, thinking that it may reset it (for whatever reason). Any thoughts on what may be going on? I just order the valve replacement kit (o-rings and clips only). I do not have a scan tool to pull the codes. Any help is appreciated.
I'm pretty sure HDC doesn't work unless you're in low range.
Get a way to read the codes. Borrow one from someone locally, rent one (I think people still do that) or just break down n' buy the abs amigo. Otherwise you can chase your tail throwing money at the problem when it may be just a single wheel sensor going flaky.
Here's an ABS Amigo for sale right now:
https://landroverforums.com/forum/pr...shipped-65714/
Dave
Dave
Dave
Dave
I would guess that you performed the ground bypass correctly since it's not difficult to do (solder ALL wire cnnections, insure good ground tie, etc.) However, since you mentioned broken clips and brake fluid flooding your shuttle valves switches. Your shuttle valves are clearly not sealing correctly which leads me to believe that they may not be rating correctly either. Even though bleeding the system is a pain, I would dismantle the modulator completely and ensure you're shuttle valves are not toast.
IMO, stay away from the ABS AMIGO device... it's a patch, not a fix.
