3 Amigo issues
Old Feb 4, 2017 | 04:06 PM
merebel's Avatar
yes i bypassed the internal connection on the shuttle valve and connected to the yellow green wire and the other to a good grond
Old Feb 4, 2017 | 04:08 PM
Luckyjayb's Avatar
did you connect it to the connector to the abs unit or to the loom going back to the firewall
Old Feb 4, 2017 | 04:11 PM
merebel's Avatar
side going back to firewall, if I did the other i would figure i get a code as it not seeing the shuttle valves lol
Old Feb 4, 2017 | 04:21 PM
Luckyjayb's Avatar
hmmmm. Did the shuttle valves ohm out ok before the bypass
Old Feb 4, 2017 | 04:22 PM
merebel's Avatar
yes they did
Old Feb 4, 2017 | 04:23 PM
Luckyjayb's Avatar
yes they did
Damn. I got me stumped now. Takes some pics of it and the ground if u can
Old Feb 4, 2017 | 04:27 PM
merebel's Avatar
i will pull the valve out again tomorrow and test it, it will be above 30 deg tomorrow so a bit easier.
Old Feb 4, 2017 | 04:42 PM
Luckyjayb's Avatar
i understand completely
Old Feb 4, 2017 | 04:43 PM
Luckyjayb's Avatar
i forgot to ask if u cleared the codes after the mod. If not clear the codes n that should fix it
Old Feb 4, 2017 | 05:04 PM
Friday Night Disco's Avatar
so far so good on my option b, might even hit the mountains tomorrow and play in the snow.
