3 amigo reset?
Old Jan 24, 2014 | 01:03 PM
sidescrollin's Avatar
Default 3 amigo reset?
I replaced my right right hub that caused my 3 amigos to come on. Will disconnected the battery for 15 minutes reset them or do I need a computer capable of talking to my ABS to reset it?
I don't want to make me engine run like crap for a coupe hundred miles and still have the lights on
Old Jan 24, 2014 | 01:51 PM
SuperBuickGuy's Avatar
IIRC it's 5 stop/starts that resets the light...
Old Jan 24, 2014 | 02:38 PM
jafir's Avatar
Wheel sensors codes usually require a scanner to clear them.
Old Jan 24, 2014 | 08:48 PM
im a little confused because i got it scanned somewhere to verify which hub and the scanner gave several other codes. The light came on after driving at highway speed (which I hadn't done before) and the wheel bearing became noticeable driving at that speed (sound and vibration).
Because of that I assume it is only from the wheel bearing being bad. It is also odd because generally when an ABS light comes on it shuts the ABS off. But with the 3 amigos on I have definitely felt the ABS working in the wet.
there is only one place in town to get it scanned and the guy it a huge PITA to deal with, so i was trying to get around it
Old Jan 24, 2014 | 08:53 PM
G Reeves's Avatar
Disconecting the batter will not clear the ABS codes, you need scanner to read, clear and reset. Where about are you as some members on here have ABS scanners that they lend out. Unfortunatly I have a genuine T4 hand held that I cannot replace so do not lend it out but will be more than happy to meet up and clear for you if you are a resnobale distance.
Old Jan 25, 2014 | 08:52 AM
dusty1's Avatar
whereyat?
Old Jan 25, 2014 | 09:35 PM
Reside in Tallahassee FL
Old Jan 25, 2014 | 11:34 PM
dusty1's Avatar
not quite close enough for me to help out.
Old Jan 25, 2014 | 11:39 PM
Colorado David's Avatar
Isn't someone on here loaning/renting an ABS Amigo?
Old Jan 26, 2014 | 11:43 AM
jafir's Avatar
I've got a hawkeye for sale.
