3 Amigos, Intermittent fault - OK to drive ?
Old Oct 30, 2015 | 03:23 PM
Harrison Andretti's Avatar
7th Gear
Default 3 Amigos, Intermittent fault - OK to drive ?
So I've had the 3 Amigos pop up while driving a couple times. When I shut the truck off and restart it , they go away.
Should I be worried about driving with this intermittent fault ?
Thanks for the replies !
-Harrison
Old Oct 30, 2015 | 04:31 PM
Dave03S's Avatar
If you are comfortable driving without ABS and Traction Control then don't worry.
When those lights are illuminated your automatic brake assist system will not work.
Old Oct 30, 2015 | 04:39 PM
7th Gear
Thanks for the reply Dave.
i don't mind driving w/o them considering my last vehicle didn't have either. Plus there isn't any snow on the ground yet anyway so I have some time to figure it out
Old Oct 30, 2015 | 04:41 PM
7th Gear
Also, I'm about to get the ABS amigo reset tool for 90 GBP.
I hear this can help fix the issue.
Old Oct 30, 2015 | 05:27 PM
Titus's Avatar
With my three amigos I actually still have ABS although my light is on. I think every truck is a bit different.
The tool will reset the codes but they will likely just come back again.
Old Oct 30, 2015 | 07:03 PM
lordmorpheus's Avatar
I remember reading somewhere some time ago that while the Amigos are present, the ABS can work, but at a reduced rate. While present, you can forget about HDC and TC. I nearly had to be pulled off a berm while wheeling a few years ago because the Amigos showed up as I was traversing it at an angle, and one tire on each axle was spinning freely.
Old Nov 2, 2015 | 08:02 AM
ATLDisco's Avatar
I can rent you my ABS amigo tool for $10/week + shipping....its gone to several members here and works great.
will let you identify exactly what's wrong so you don't go throwing parts at it.
Old Nov 2, 2015 | 08:08 AM
drowssap's Avatar
for another $35 you can get icarsoft scanner that will read you abs, sls & read and clear any obdii codes
Old Nov 2, 2015 | 10:13 AM
7th Gear
I may definitely have to take you up on that.
I'll inbox you !
Thanks a bunch
Old Nov 3, 2015 | 10:00 AM
mln01's Avatar
Thanks lordmorpheus, for reminding me to go look up the facts about how the ABS, etc. function when a fault is detected and the Three Amigos pay a visit.
The boys from south of the border don't necessarily indicate that your ABS is disabled.
I've attached RAVE pages 876-877. On 876 (70-23) it says that a shuttle valve switch fault is considered a "permanent fault," which remains illuminated until cleared and which means that if the OP's Amigos are intermittent he has a different problem. (Despite that I recall my Three Amigos being intermittent until I did the Option B bypass in January 2011 after my ABS Amigo indicated a shuttle valve switch problem.)
Page 877 (70-24) shows the default strategies that are employed when an ABS fault is detected. A shuttle valve switch fault (by far the most common based on forum traffic) disables the traction control and hill descent control, and degrades but does not disable ABS and electronic brake distribution.
There have been a lot of incorrect posts on this and other LR forums claiming that the Three Amigos mean that ABS is disabled. It is not in all cases. The table shows that ABS is disabled in four of the seven default strategies. And in all my years on this forum I have never, ever seen anything other than sensor faults and shuttle valve switch faults discussed.
So yes, Harrison, it's okay to drive your truck with the Three Amigos lit up.
File Type: pdf
