3 Amigo's just a question
Had the random 3 amigos today on the way to work, when I had a chance I went out to pull them. But when I fired up the Disco to move it to a more work friendly spot of course they were gone.
Does anyone know if a pending code is saved ?
This happened once before about a year ago and they never came back, until now.
I get the same on mine a couple of times a year, ever since I put in an ‘03 SLABS. It has only happened after hard acceleration after a stop. If I turn the key off for a few seconds the lights remain, but if I turn the key off for a couple of minutes the lights go away and stay away (for another half year or so). I think it’s a non issue myself.
Richard Gallant (09-29-2021)
I got the 3 amigos on an off-road tour. Used HDC a lot when the car was shaking heavily. I bled the brakes in the evening and there was some air in the fronts. After I came home I reset the codes and they never came back. Maybe you should do a brake bleeding to sort that out. It is a very simple job with a power bleed (short connect the ABS relay switch).
If you get that happening before Option B you probably have bad insulation on the shuttle valve Switches or the internal connector is causing it. If you have performed Option B and it does it either you didn't cut the connector off which goes up inside the Wabco Unit (have found this a lot lately on several D2's), or the ground isn't good enough.
The Deputy (09-30-2021)
Richard Gallant (09-30-2021)
Richard Gallant (10-01-2021)
