3 amigo's questions
Old Jun 12, 2018 | 02:58 PM
razorkill12's Avatar
Originally Posted by zuke
I am about to tackle the 3 light problem myself. If option B fixes the problem will the lights clear or do I need the special unit to clear them?
i JUST did option B repair and had to use a scan tool to clear code...So I would say yes you need one.
Old Jun 12, 2018 | 03:26 PM
OffroadFrance's Avatar
All codes remain resident in whatever ECU until the faults are fixed, the codes highlighted and then cleared. You need a diag tool to highlight and clear codes.
Old Jun 13, 2018 | 07:57 AM
jastutte's Avatar
ABS Amigo V1 USB
I picked up a used one of these to use on my trucks.
Old Jun 13, 2018 | 11:15 AM
Best4x4's Avatar
Any fault code for the ABS is stored in the SLABS Unit & can only be cleared with a LR compatible scanner than can read ABS codes/faults. Only ECU on a D2 that won’t store codes permanently is the ACE ECU.
Old Jun 13, 2018 | 03:44 PM
Richard Gallant's Avatar
Good news (?) for me my modulator passed all the basic electrical tests and no brake fluid on the switches. Now I can clean the truck and check all the sensor connections, while I wait for the Navcom.
Old Jun 21, 2018 | 10:36 PM
Update got the nanocom loaner, thanks ACG, the left rear sensor had 16 intermittent faults.
Cleared the faults drove and tested all is good on that front.
Figured I would do a power bleed while I had the gear, brake fluid from left rear was literally almost black over 5 cycles,right rear was a only a bit discolored.
Looks like a full brake systems flush is in order.
Old Jun 23, 2018 | 01:51 PM
Default bad Brake Fluid
This is what came out of my right rear when bleeding - there is a piece of hose in there too. If you are not familiar with brake systems this is bad you need to do a full flush and brake test.
My pedal stays solid so no leaks, but it will take a couple of liters of fluid through, to make me feel good about the the system.
bad brake fluid
Broken08
Jul 31, 2015 03:49 PM
me 2
Apr 9, 2013 12:12 PM
bostongrun
Apr 30, 2012 11:07 AM
GadgetRick
Feb 9, 2012 10:18 PM
maxman
Nov 29, 2010 11:19 AM
