The 3 amigos were hiding
I knew it was to good to be true. I made a rookie mistake and didnt check to make sure all the warning lights lit up when the I turn the key on. LOL Well I was reading thur some old thread and ran across one about folks covering the three buddies up where they cant be seen. Well guess what my 3 little buddies was covered up. Now they are shining in all their glory, plus the service engine soon and brake light too. lol. I love it! (not really loving it)
That's a bummer.
Just imagine that an accident happens because the tampered warning lights did not show a safety dangerous failure condition.
If you get out of it alive, could be a great time for a lawsuit to the idiot who tampered with the warning indicators. All bones broken, but a big bank account.
That should be punished by law .
Sounds like a MAF issue. The O2 codes may be caused by the MAF. The p1590 is more or less a generic ABS code. You are going to need a better scanner to determine exactly what the ABS problem is. When I got the Amigos the first time, I had a P1590, and shuttle valve repair fixed it. Years later, Amigos returned along with P1590, and I had to replace the SLABS ECU.
Upon reading on the abs codes, the sensors on the wheels are either dirty or bad, or the slabs ecu is bad like lordmorpheus said.
If you have alot of brake dust on the wheels, this could mean the sensors are dirty.(If you have to clean the wheel often because of brake dust) This is the reason I went with ceramic brake pads.
