3" vs 2" OME ---> Help!
having just done to swap to duratracs and a OME 2" medium lift i can tell you i am perfectly pleased with the set up. a bit stiff on road, but off road it hits and soaks up bumps,ruts, and holes easily. plenty of height to get over anything i need it for. and i went from a 29" tall tire to a 32" so i gained some height on sidewall as well as sprung height.
3" is overkill in 99% of the applications.
Kind of what I'm worried about. I think I'm going to stick with my original plan and go with the 2" kit and throw some spacers in the rear to level it out since I'm not going to have anything too heavy up front and I do not want the saggy a$$.
Thanks for the input. I am definitely going with Duratracs white lettering OUT.
Anyone have any idea if spacers in the rear would be a bad idea?
Can I just point out that when lifting the car with either 1" spacers, 2" or even 3" inch springs ....it has ZERO effect on the brake lines and ABS wires.
The length of those 2 need ONLY be addressed if you fit shocks with an extended / longer travel than the factory shocks. The shock is what limits the axle travel and governs everything else.
So IGNORE anyone who says "I have a 3" lift and have no issues with ABS or brake lines"....... because its the SHOCKS that matter.
So until you know what "that person" has done with the shocks, I would take it as hearsay. I "Believe" even OME shocks dont allow that much more travel than the factory shocks, have not seen one to compare tbh, but thats "probably" why people don't / need to extended anything as in general OME stuff is designed as a direct replacement and if the extensions to the ABS and Brake lines were required Im 100% sure that ARB would state that in the details / instructions that come with the shocks.
As an example......I have OME779's and SLS spacers on mine which give about 1.75" of lift, I also have +2" Extended terrafirma shocks, which 100% required brake line extensions as they allow the axle to drop significantly further. The front ABS lines can be re-positioned to give enough length (just), but with the rears on mine that was not possible, so they have been extended by about 2" as 1 was nearly disconnected on a "play day".
...As an example......I have OME779's and SLS spacers on mine which give about 1.75" of lift, I also have +2" Extended terrafirma shocks, which 100% required brake line extensions as they allow the axle to drop significantly further. The front ABS lines can be re-positioned to give enough length (just), but with the rears on mine that was not possible, so they have been extended by about 2" as 1 was nearly disconnected on a "play day".
![EEK!](https://landroverforums.com/forum/images/smilies/bmHv6Xb.png)
I'm glad you chimed in on this UP...I've just ordered a 3" TF lift with their +2" shocks, and was going to delay upgrading to the extended brake lines. Based on the above, I guess I'll need to bump them up my list of mods...
![Wink](https://landroverforums.com/forum/images/smilies/Uh2vXQr.png)
Thanks for the input UP.
DF, that is the way I interpreted you post so no worries, you didn't lead me astray in any way. I'm ordering a TF steering stabilizer today to get that started, then springs & shocks next week (or the week after) when my new credit card comes in, going to rack up some airline miles REAL quick![Big Grin](https://landroverforums.com/forum/images/smilies/lxvR5hR.png)
......man I REALLY love the stance of a true 2"+ of lift.
