3" vs 2" OME ---> Help!
#21
Also, please be aware that with +2" extended shocks, your front prop will hit the front crossmember, so that has to be "addressed" as well.
#22
#23
UP, You don't happen to remember the dimensions of the spacers you made for your crossmember, do you? I didn't see the measurements out on your site...
#25
#26
I was considering lifting my Kalahari simply by putting a 2" lift spacers. I am trying not to spend much $. Thoughts? if think it is a good idea, what brand would you recommend?
Also, what tires would you recommend. Currently with 255 65R16. I appreciate your comments and input
TerraFirma is quickly becoming a very popular brand around here and is slightly more affordable than the OME.
Don't be afraid to use the search function, there's lots of good info and discussions on this forum and you'll often find the info you're looking for has already been discussed at length.
#27
#28
I would appreciate it. Ordered by steering stabilizer but haven't gone for the lift yet. Thanks! What size tires you running?
#29
#30
They are about 14mm thick, seems to be enough on mine and a friends, but different cars "may" be slightly different.
