4.6 - Oil Leakagage
Old Jan 24, 2015 | 11:17 PM
ThomasFS's Avatar
Default 4.6 - Oil Leakage
Hi Folks,
2 days ago I bought a 2003 Discovery, 4.6 HSE, with 130000mls.
Today, after a 30 miles trip on the highway, the car had a lot of smoke behind, coming from oil drops burned on the hot exhaust.
I can’t see exactly, where the oil is coming from, there is all over, beginning from the front axle to the transfer case.
What are the typical problems which could cause a oil leakage which I could check tomorrow.
I’m new to the Discovery, but I owe a Defender since 2002.
Does somebody know a good workshop to bring the Discovery for a repair?
Tanks a lot in advance, and sorry for my poor English, I’m from Germany.
Picture after arriving home:
Last edited by ThomasFS; Jan 27, 2015 at 12:37 PM. Reason: Misstype in headline, bad for searches.
Old Jan 24, 2015 | 11:26 PM
dusty1's Avatar
That is a lot of oil
Are you sure it is all oil?
Valve covers are known to get lose and let oil out.
Old Jan 25, 2015 | 05:21 AM
bmeier's Avatar
I would check oil pan too, looks like its getting all over your "undercarriage" .
Old Jan 25, 2015 | 08:47 AM
dusty1's Avatar
And front cover.....looks like it could be coming from front of engine.
Old Jan 25, 2015 | 09:07 AM
My guess would be the front cover leaking or the valve cover gaskets, probably both.
This guy in Florida is a well regarded member of the Rover community not sure where you are located though...
The Rover Shop, Fort Lauderdale, Florida 954-767-6837.
Old Jan 25, 2015 | 09:08 AM
ThomasFS's Avatar
Thanks for the input until now, after some research I will now start to have a look to the disco. I hope the issue can be fixed, because I like the car very much, besides I only owe it since some days and drove it only for a couple of miles.
Here some pictures from it's best side:
Old Jan 25, 2015 | 10:07 AM
ThomasFS's Avatar
We are in Orlando FL, a shop nearby would be helpful, but thanks for the contact in Fort Lauderdale. I guess he can give some helpful hints what I could do.
Old Jan 25, 2015 | 10:59 AM
RicketyTick's Avatar
Check the screw in plugs in the front oil pump/timing cover where an oil pump would connect. 2003 doesn't have an oil cooler and the blanking plugs they used to delete it do get loose. I had one back out part way and was getting oil all the way onto the back bumper. Screw in plugs with a hex head for a socket...don't remember the size.
Old Jan 25, 2015 | 12:11 PM
dnice's Avatar
It's all over the place from blowing back while driving. I'd clean the area real good so you can do a proper diagnose of where it's coming from. As stated above it could be coming from valve covers, front cover, etc.,
Old Jan 25, 2015 | 08:47 PM
ThomasFS's Avatar
Today I did some cleaning and I think the oil is coming somewhere from the upper region of the front engine cover.
I also found the screws of the oil pan a little loose, but not much, and tightened them.
Tomorrow I try to find a mechanic to have a look to the oil leakage.
What could be the average price, to put in a new seal to the front cover and the oil pan?
Any suggestions for a good mechanic for Land Rovers in Orlando FL?
Thanks in advance ....
