4.6 swap lean codes
Old Jun 2, 2020 | 03:29 PM
oldhamsaints's Avatar
7th Gear
Default 4.6 swap lean codes
I just installed a 4.6 in a 2001 4.0 and now I am getting 1171 and 1174 lean codes.
New Bosch MAF, swapped front O2s from a running truck, smoke tested for leaks none found but still getting codes
Could it be that I need to remap the ECU?
Old Jun 2, 2020 | 06:16 PM
7th Gear
Default my truck
Old Jun 2, 2020 | 08:06 PM
XRAD's Avatar
Nice look. Something different. What was the 4.6 doing before the swap? Did you rebuild it? new intake gaskets? injector O rings? Did you use the 4.6 ECU and AFM (not necessary if non SAI to non SAI, as I have the same swap)
Old Jun 3, 2020 | 05:23 AM
7th Gear
XRAD. I bought a used engine and totally rebuilt it. I did not have the 4.6 ECU and AFM. It is not SAI
Old Jun 3, 2020 | 07:29 AM
XRAD's Avatar
Ok so start with an intake leak test with spay. also check you fuel trims to see where you are (on your diagnostic scanner). I had rich lean codes driving me nuts until I replaced the O2 sensors with walkers and used an old 4.0 MAF.....
abran
Mar 9, 2022 11:46 AM
badassbmwm3
Mar 29, 2015 06:26 PM
cornbreadj
Feb 18, 2014 02:06 PM
Bryan H
Nov 30, 2012 10:18 PM
d2luvr
Nov 27, 2009 02:13 PM
