Is 400-500 rpm idle normal?
Old Jun 26, 2009 | 11:43 PM
IDAHODISCO's Avatar
Angry Is 400-500 rpm idle normal?
I did the throttle body cleaning but still a low idle? It will sometimes hold at 700 rpm but when I drop it in gear it will some times go as low as 400-500 rpm??
Any Ideas...
Old Jun 27, 2009 | 05:30 AM
lipadj46's Avatar
Did you clean your idler (or whatever its called) also?
Old Jun 27, 2009 | 05:36 AM
How do you know its at 500rpm? Are youi using a scanner or the tacometer?
Just a FYI the rev counter is not accurate.
Old Jun 27, 2009 | 07:13 AM
oysterhead's Avatar
Is it idling rough, or are you just concerned with the value of the RPMs?
Old Jun 27, 2009 | 08:33 AM
So, it may be time to get back to the basics.
How many miles, what octane, when was it last tuned, were wires replaced and have you cleaned your idle control solenoid yet???
Old Jun 27, 2009 | 09:41 AM
IDAHODISCO's Avatar
I am going of the dash display!
It did run a little rough before the cleaning cant get it to do it again but my rpm on my display are low?
I replaced the plugs with some pluse 4 6 month ago.
I never touched the wires allthogh they look new.
I use the good gas 93-94 oct.
I dont know when or if it was tuned?
I dont know where the Idle Control Solenoid????
Old Jun 27, 2009 | 10:08 AM
What color are the plug wires and do you have a check engine light on?
Old Jun 27, 2009 | 10:50 AM
IDAHODISCO's Avatar
They are Spark pluge wires are Spark Tranfer International "STI" and they are bright Blue they look good? No Check light on!
I started it this morning and it stayed at the 700-800 rpm after 15 min it droped down to 400-500 rpm I cant hear the change or feal it when I put it in gear and let it roll?
Where is the Idle Control Solenoid?
Old Jun 27, 2009 | 04:36 PM
Your idle is fine, if its not stalling then dont worry about it.
You wnat your idle to be low when warm, if its to high then you are wasting gas.
The tac on the dash is far from accurate, mine reads 500rpm but my scanner reads 650-700.
Old Jun 27, 2009 | 04:49 PM
IDAHODISCO's Avatar
That's good to hear!
It was running rough before I did the throttle cleaning I guess it was a little gunked up and now it fine well so fare so good!
