4th gear shifting late
Old Aug 8, 2013 | 03:56 AM
kristoffersmith's Avatar
Exclamation 4th gear shifting late
Hello all
I have a 2000 discovery with 156k miles now and recently I have noticed that my truck will sometimes delay the 4th gear shift until im going 50+ at 3200 RPM. It only does this with the 4th gear and it doesn't always behave in the same manor. It seams that if i drive it more then 20 minutes or if im driving it a little harder then normal it will have this issue. I have also noticed the shift from 3rd to 4th under acceleration is not always a smooth one.
I should also mention that I replaced the ATF some time last year. however i did not replace the filter.
Old Aug 8, 2013 | 06:41 AM
jeffh's Avatar
I would drop the pan replace the filter and fluid. drive it and do a repeat on the fluid only. add some lucas transmission conditioner. You may find it shifts fine after the first fluid and filter change but for safety I reccomend the second fluid change. gunk build up will come loose and may prematurely begin to clog the filter again. My 2 cents.
Old Aug 8, 2013 | 07:19 AM
NickAdams's Avatar
On many automatic transmissions, these symptoms indicate low fluid level. Have you checked yours?
Old Aug 8, 2013 | 01:05 PM
dusty1's Avatar
x2 on level. upon changing you need to fill, then cruise the nhood to work the full range of gears, then refill.
i have had low levels cause slow/delayed shifting, sticking and hard shifting
Old Aug 8, 2013 | 01:27 PM
Thanks for the replies. I will be checking the level once more and try adding some fluid. If that does nothing I'll change filter and oil out again.
Old Aug 8, 2013 | 01:32 PM
Do you know how to check the fluid level?? It can only be checked with the engine running.
When checking see what color the fluid is crystal red or a little brownish.
Old Aug 11, 2013 | 05:03 AM
at first glance I thought my fluid was crystal clear but I pulled about a cup out into a jar and i cant see more then an inch into it. Guess its time to change the oil and filter again
Old Aug 11, 2013 | 07:33 AM
If it is that bad plan on doing 2 drain and refills, the second one you should consider adding a bottle of Lucas tranny additive.
Old Aug 11, 2013 | 10:28 AM
roverguy7's Avatar
Another thing that can cause issue with 4th gear is the MAFS reading.
I agree with changing out the fluid/filter, but if you are still having issues, and they are solely related to 4th gear, take a look at the MAFS, make sure there is no debris on the screen, and maybe try to clean it.
Old Aug 11, 2013 | 03:05 PM
Dave from what I have seen in the past, if the MAF isn't throwing a 100 to a 105 code, but is throwing codes for both banks being rich or lean along with a 734, there is a great chance the MAF is going south, but he hasn't mentioned and fault codes.
