4x4 transmission
Old Jul 22, 2007 | 05:57 PM
wadey's Avatar
Default 4x4 transmission
hi there im new to the forum i live in spain have a 97 disco and since using the 4WD i have disengaged it but it still seems to be stuck in it at low speeds and is causing a juddering and snatching sensation on all 4 wheels at low speeds. can i still drive the car and what causes it and how do i rectify the problem,thankyou
Old Jul 22, 2007 | 06:04 PM
okdiscoguy's Avatar
Default RE: 4x4 transmission
are you familiar with how the transfer case works?
If you arestuck in diff lock, do slow circles in reverse. Sometimes it winds up and takes a little while to disengage. Don't go over 40 on dry pavement with it engaged. If you are stuck in low you won't be able to go much over 40.
richand26mhz
Jan 19, 2006 06:10 PM
05LandRover
Off Topic
Aug 18, 2005 02:45 PM
diamondgeezer
Sights N Sounds
Aug 3, 2005 04:18 PM
motoxxxracer_34
May 20, 2005 01:24 AM
asmcmillin
Mar 19, 2005 12:51 AM
