#5 Cylinder Misfire Detected
Old Oct 23, 2007 | 01:06 AM
xb70valkarye's Avatar
Default RE: #5 Cylinder Misfire Detected
What is a BG44?
Old Oct 23, 2007 | 07:56 AM
BG's 44K is one of the best gas additives you can use, also the most expensive but worth every prnny of it.
Lets talk about your misfires and work that you should plan on doing.
303-862-7680
Colorado between 7 am and 8 pm
Old Oct 23, 2007 | 08:01 AM
mcneal's Avatar
Mike - OKDiscoguy - How easy it it to DYI on changing out the wires. I have no room at all behind there. Literally its like 4 inches max to fit my hand. I don't want to have to start taking stuff off unless I have to.
[/quote]
I apparently have large hands, i didnt realize until i changed my wires. At first is was a real pain. I did them one at a time and had a really hard time with a couple.looking back, i would start with the outside ones and get those first. then take the remaining 4 wiresoff the better access to the middle bottom ones. get the bottom and move to the top.a copy of the rave CD to show firiring order is a MUST. Hope that helps.
Old Oct 23, 2007 | 12:50 PM
okdiscoguy's Avatar
I have a D1, took me 10 minutes.
If you have secondary air, I hear it is very difficult. I think you may want to remove the intake...
aBs0lut30
Aug 14, 2021 05:07 PM
scarrell
Nov 16, 2012 06:04 PM
03DiscoSE
Apr 2, 2009 03:17 PM
mtat
Oct 2, 2008 10:03 PM
auburndmbfan
Mar 23, 2008 11:09 PM
