64" Wide Headliner Material Source
Old Aug 2, 2022 | 06:37 PM
  #21
TimInNova's Avatar
Originally Posted by MSGGrunt
Where do I find this elusive 64" wide material? Seems 50" and 60" are readily available, but 64" I can't seem to find.
64" wide is what is needed to redo a Disco 2 headliner yes?
The fabric was only 54" wide, so I had a seamstress cut it and sew it to give me a piece 64" wide x 108" long.. A center section that was 54", and then two side sections 5" each sewn on. It came out perfect. Here's my headliner:
https://landroverforums.com/forum/di...79/#post748483
Old Feb 16, 2023 | 10:44 AM
  #22
Overseas Living's Avatar
Headliner question - for those that have removed and replaced their headliner, did you also add silencing material to the roof? Did the old stuff come off easily? I'm teeing this up in the coming weeks and want to have plan to address noise abatement and such. TIA.
Old Feb 16, 2023 | 12:01 PM
  #23
mollusc's Avatar
I put heat shielding acoustic foam behind the headliner while I had mine down. There was not really any "old stuff" to remove but if you want to clean the residue of the old disintegrated foam off the headliner while you have it out, a wire wheel works perfectly.
Old Feb 16, 2023 | 12:29 PM
  #24
TimInNova's Avatar
"Headliner question - for those that have removed and replaced their headliner, did you also add silencing material to the roof?"
Yes, as much as I could fit. The truck is quieter now as it cuts down on wind/exterior noise.
Old Sep 25, 2024 | 01:47 PM
  #25
Landrolet's Avatar
Thank you so much WaltNYC for recommending albrightsupply.com, I just got 67" wide 3 yard, Liberty WEH Extra wide headliner sand gray. That looks like a good match for it and it was $106.04 OTD compared to $316.27 from headliner express
Old Sep 25, 2024 | 02:31 PM
  #26
CharminULTRA's Avatar
Damn I wish I had went this route rather than Headliner Express. For anyone doing this in the future, would highly recommend using 2-3 people to do it. Very difficult to get it right as 1 person and resulted in a lot of creases.
TyTyBinks
Jul 1, 2020 10:23 AM
BrandonG83
Apr 30, 2015 02:47 PM
jalodge
Sep 22, 2013 12:12 PM
ATXDisco
Sep 21, 2010 09:37 PM
discoguy
Jun 22, 2008 04:00 PM
