7 codes after o2 and MAF replacement
Old May 16, 2014 | 03:02 PM
hankeester's Avatar
Default 7 codes after o2 and MAF replacement
I went to start the disco today and it's running extremely rough with a blinking CEL. The codes are 0130, 1071, 1300, 0305, 0307, 1319 and 1171.
I swapped out the front 02 sensors a few weeks ago and was still getting the 130 code so I then installed a new MAF sensor and the 130 code never went away. It has 113K miles on it. I have also noticed over the past 1-2 weeks, everytime I start it, black soot comes out of the tailpipe and soils the concrete, if that's anymore of a hint of what could be wrong.
Old May 16, 2014 | 03:13 PM
ralphobell's Avatar
Those are cylinder misfires and running lean codes. What happens if you place the old MAF back in it?
Old May 16, 2014 | 03:36 PM
hankeester's Avatar
I threw it away already. Was that a bad move?
Old May 16, 2014 | 05:00 PM
ralphobell's Avatar
Were you getting those codes before you changed it? What brand did you go with on the new MAF? Did you replace the O-rings?
Old May 16, 2014 | 05:54 PM
hankeester's Avatar
The only codes I had before changing it out was the 0130 code. I replaced with a Bosch and I did not replace O-rings. Possible that I didn't get it seated right in the plumbing or the clamps aren't tight enough? Would any of that matter?
Old May 16, 2014 | 07:23 PM
hankeester's Avatar
Can't even find a place to buy a new o ring. AB only has them for Range Rovers
Old May 16, 2014 | 07:29 PM
ralphobell's Avatar
And you surely hooked the cable back to the MAF right?
Old May 16, 2014 | 07:51 PM
hankeester's Avatar
As someone else quoted on here, "I am mostly an idiot." Nix this entire thread as I just found that the clamp around the plumbing that goes into the throttle body was not tight, causing all of this. The 130 code that I had after the 2 new O2 sensors and MAF sensor is also gone.
Signed,
I am a dumbass
Old May 16, 2014 | 08:07 PM
ralphobell's Avatar
Good to hear, well not that your an idiot, but that it was an easy fix.
Old May 16, 2014 | 08:23 PM
hankeester's Avatar
It sure was, and I know I'm an idiot for not checking. Explains the bit of rough idle I've had for the past few days, before it went to horrible idling and felt like running on 7 cylinders today.
