90 octane pure gas in 2004 D2?
Old May 17, 2023 | 08:36 AM
  #31
sqlbullet's Avatar
Originally Posted by L33DiscoII
Regarding ethanol; it has about 27% less energy than non-ethanol fuel. You'll lose some MPGs running ethanol gas. Since ethanol makes up a maximum of 10% of the volume of the fuel, only 10% of your tank (about 2.4 gallons) has about 30% less energy, the rest is regular gasoline. The difference in normal driving shouldn't be very noticeable and the cost difference should be close to a wash, if not a bit cheaper to run ethanol. Never run E85. It'll do bad things because the computer can't manage it. Vehicles that can run E85 have sensors in the fuel line that detect the level of ethanol and the ECU adjusts the tune appropriately. Without that, E85 can really damage an engine. A show called Engine Masters did a really neat episode on "flex fuel" recently (season 7, episode 21).
Excellent post!
One addendum to ethanol. Even though it has less energy density than gasoline, in a properly tuned engine ethanol will make the same power. This is because the ideal air:fuel ratio is different for ethanol, so you can get much more fuel into a cylinder. The accepted gasoline air:fuel ratio is 14.7:1, while ethanol is 9:1. Doing all the math in a perfect scenario ethanol will make 99.6% of the power gasoline will in the same cylinder. MPG will suck, but power is about the same.
Again, this assumes the engine is tuned for ethanol, or has special sensors that allow to vary it's fuel map based on the ethanol ratio detected. Our disco's don't have those features.
Old May 17, 2023 | 09:44 AM
  #32
NVDiscovery's Avatar
Excellent post by L33Disco2 on octane and how engines work. If running high loads/hot temperatures, I would always opt for a slightly higher octane as those situations create stress that can induce knock.
FWIW, my "seat of the pants" review of 90 vs 93 says that the 93 performs a bit better. I notice better pull on uphill sections although I never had any codes or anything with the 90 pure gas.
Old May 17, 2023 | 10:02 AM
  #33
ahab's Avatar
You should notice more power with higher octane in an engine that can dynamically adjust timing. By raising the flash point of the fuel you can move the spark timing further into the engine's rotation without risking preignition that would occur due to heat and pressure. Think of riding a bike up and over a ramp, the pedals are really hard to press as you get to the crest but then as you transition to the down side they get increasingly easier. This isn't actually what happens in an engine but should give you a mental picture of the spark happening a few degrees before or after the peak of the incline. Before the peak is preignition which counters the rotation forces and is really bad, too far after the peak and you get into valve actuation which is also bad but for a different reason. Those few degrees in between make a big difference in performance.
NewToTheTwo
Oct 12, 2019 07:57 PM
jbarr89
Jun 21, 2016 12:43 PM
mag48
May 18, 2009 09:52 PM
wesley64
Sep 11, 2008 08:02 AM
Chrisinhouston
Dec 19, 2007 10:20 PM
